Two Superhub IP Addresses?
7 Jun 2005
North East
OK, forgive my foolishness...
I have a Virgin Superhub 2. The default IP was always 192.168.0.1. At one point I had it set to modem mode and another router attached. Since reverting to router mode the IP is now 192.168.100.1
What is strange is, both 192.168.0.1 AND 192.168.100.1 both take me to the Superhub login. I'm confused?
I plan on setting up static IPs on all my devices and disabling DHCP, in the hope of resolving a separate issue. So which IP do I point my devices to for the router? :confused:
Likewise, should my assigned IPs be 192.168.100.x or 192.168.1.x ?
192.168.0.1 is the newest IP to access the GUI.
192.168.100.1 is the old modem config IP address.
If you are using is it as a modem use the routers IP address that would be connected.
If you are using the Superhub as a router/modem use the 192.168.0.1
Hope this helps.
