Two watercooling system in a CM110. internal, with pics!
Don
21 Oct 2002
Parts Unknown
ok, here's my pc 6 months ago, had the watercooling for ages, but at this point had 2x raptors whining away bolted to the sides of the hd cage (pump + tubing is where they should be)
was also getting a bit too hot with gfx card + cpu block that needed cooling
^quite crowded in there!
last week i took it apart to clean -been about 2 years of same water in the pc!
def needed a clean!
bought myself some new kit so i can cool + quiten my raptors and not have to worry about the extra heat in the system, thought of this in my head..
was a bit different originally, but this is best way i reckon!
this is it with one of the systems in place to cool gfx + hd's (yesterday)
this is it tonight with BOTH in, just getting the air out of it now before tidying up the T tubes!
the kit i have..
system 1
1250 pump
black ice extreme
cathar lrww block
system 2
1046 pump
silentstar dual hd block
innovatek 6800gt block
'w00tan' res (made for shuttles)
waiting on my new black hiper to arrive tomorrow and i'm done
also using a silenx 120mm fan for main rad, and 3x sharkoon 9db fans for the rest
suicidle_tramp said:
Nice set up! :D:D:D Why is there only one tube going to the cpu block?
Cos he's still filling the system, notice the pipe coming from the top of the pump with the red funnel attached :)
I've got a fully internal water system in my CM110, been meaning to post again for a while since it was all changed again. I did a lot of work on the drive cages tho to get the rad and shroud in there first....
Nick
