I've fitted a second switch in my garage so that I turn the lights off from either end of the room, however, one of the switches isn't able to turn the lights on - only off.
I followed the diagram here and I've double-checked everything is wired per the plan but I can't work it out.
Switch 1 (that only has 3 core and earth) can switch the lights on and off.
Switch 2 (that has the twin and earth as well as the 3 core) can switch the lights off if switch 1 turned them on. It can't turn them on.
Any ideas on what to check?!
