At home I've got two belkin wireless routers (One a cable one which is being used, and an adsl one that we don't use now), and my brothers PC is at the opposide side of the house, so has poor signal quality. Now, I'm pretty sure there is a way you can use the second router as a go-between so the internet signal goes through the cable router to the adsl router which relays the signal to the PC, and vice versa.
I know there's a proper name for this, but I can't remember otherwise I would google it.
Thanks ^^,
Thanks ^^,
