Type of Ethernet cable and outside help
Permabanned
14 Jun 2009
My mate has a make-shift recording studio in his garden with a pc in it. It is soundproofed and he can't get a wireless signal for the internet in there.
Now, he wants to run a cable, approx 30m long from the studio, through the garden, through conservatory and into the house where the router is.
What type of Ethernet cable is best?
Is it ok for burying it in the garden or outside with all weathers? If not, what would you suggets?
Any advice would be very helpful indeed. Ta
Twisted pair?
You'll see this if you've ever taken the insulation off a network cable or made one by hand, the wires are twisted round each other to form four pairs.
Cat5e or Cat6?
Both are rated for gigabit (Cat 5e has unused wire pairs that can be harnessed for more bandwidth), however Cat 6 may be more expensive since it 100% guarantees gigabit speeds.
I would put the cable into some garden hose under the soil. Would that be ok?
I'd think so, yes.
Ok, so Cat5e then. Twisted or not? It would fit in a garden hose you think?
Then just plug one end into the router, route cable and plug the other to the PC in the studio in the garden? (drilling wall and making good etc.)
Tip for threading cable down a hose pipe
Long piece of string,wad of cotton wool,tie to one end of string
Compressor (small home garage type ideal)
push one end of string with wad into hosepipe put end of compressor pipe after it turn on air and feed string until at other end of pipe :) attach cat 5 etc and pull through
Did this to run a cable to open the electric gates at the end of our drive 30 m+
When
What a fantastic idea. I might do that myself when I wire up my shed. :D
Anyway. The only other way to do it is through some kind of shielded conduit like metal pipe, but this will be a bit more expensive than garden hose. The downside of garden hose is that it will act as a giant ariel so he might get packet loss. YMMV.
Even if it is 100% plastic?
For outside you want solid core cladded Cat5e.
Even if stranded cable is in the hose it'll still fracture in the cold.
It's not very expensive, so it's worth it to save the hassle.
