Typing Issues
14 Apr 2010
I have a netbook and it is a real pain to type on as the cursor keeps jumping about all the time i write!! I could be typing a sentence and the cursor would then jump to 3 words back or some lines back and i have to replace it all the time!!
Any ideas as to what is happening? Doesn't happen on my wifes laptop when i use that?
you are touching the touchpad...
turn down the sensitivity...
if you dont have the option, you need to install the touchpad drivers...
there is also some times an option to turn it off - a button on the keybaord... (only realy of any use if you are using an external mouse)..
