Everywhere i spoke to wanted £12-17.
Remember, with Camskill though you have to factor in the cost of delivery too. Have you looked at blackcircles?
That's ridiculous! You can get a puncture repaired here for only £3 more than £17.![]()
Theres two places around here I know the price of. One charges by the wheel rim diameter, £1 per inch and the other place is £20 per wheel for fitting and balancing a tyre you supply.
Where is that cheap mate? I have never known anywhere to fit for as little as that.
Ironically, puncture repairs are £12 at the local place, but try and get them to fit your own tyres and they bark at you and want £20.
No you misunderstood, puncture repairs are £20, which is £3 more than he is being charged for just a tyre swap. Your example is even more extreme though!
It's £10 a corner around the various tyre places here for a swap. When I were a lad in the early 90s the local tyre place used to be pound off, pound on and pound for balancing though (if he wasn't busy).![]()
I didnt, i perhaps worded my reply badly. My point is that £10 is very cheap, i need to come over your way to get my next set fitted by the looks of it![]()
Jesus
i pay £5 a tyre for punctures and changovers up here inc fitting/balancing best of all its literally 400yards from my house too![]()
Just rang a couple of places and the cheapest wanted £17 per tyre
