Tyre help needed
14 Jan 2005
Recommend me some 195/60/R15/88/H Spec tyres.
Currently have a combo of Pirelli P6000's on the back and Avons at the front, which I dont really think are optimum.
Budget is about £50 a corner (pref including delivery) :)
[TW]Fox said:
Goodyear Hydragrip or Conti SomethingContact.
Ok, just to add... really looking for an all round tyre which have decent grip in both wet and dry conditions and preferably last for a year (around 8k miles).
Will the above mentioned be ok for the purpose ?
Both will last for double that normally.
Just checked on mytyres and the Goodyears are 47.80 incl delivery :D. Fits nicely under budget.
Thanks for the help guys. Gonna place an order now. Any idea how long it normally takes for delivery ?
Took about a week when I ordered mine.
