You can get a decent set for under £150, plus fitting. Not sure what's so expensive about that, given that decent tyres are one of the biggest things that will stop you from crashing...
The supercorsa about 5 years ago were called BSB.... exactly the same tyre expect the BSB was %40 cheaper.... Again its the same tyre same mould tools (apart from the insert for the lettering)
But yes it aint cheap.
Doing a euro one next year as the main hols which should be fun.
I read that the BSB's were a hard compound as they were designed for the road, compared to the normal Supercorsa's which were SC0,1,2 and the BSB is like an SC4 or something like that... thats why they are much cheaper.
Hey, at least you have a choice... I'm supposed to be using Crossply tyres, and in an odd size to boot. I pretty much have the choice of two brands, one model each, and even then one of those has decided to replace theirs with a really crappy new version.
My only option is the expensive one.
