Hi, I thought I'd try here before signing up to a couple of the more specific BMW motoring forums, I have a slight dilemma regarding new tyre(s) and sizing
I have an e93 m3 with 19" tyres - currently the rears are contisport contact 3 fairly recently replaced (i had a scrape and ended up getting one replaced on insurance and then the other one needed replacing a few weeks later - I missed a chance to swap to michelin PSS which I hear is probably the best all around tyre for this car... - the fronts are contisport contact 5p.
The front nearside needs replacing very soon, and while looking into that I've realised that the tyres I have on the fronts at the moment are probably not quite right - they are 235/35 when they should apparently be 245/35, but I understand some actually choose to use the 235s for some reason. They are also OE keyed RO2 (which is quattro 4wd I believe) which isn't quite right.
So I have a decision - do I replace the one that needs replacing like for like from halfords for about 150 quid, car seems to drive pretty well as is, OR do I replace both with more appropriate 245/35 tyres at about 200 quid each and maybe switch to the michelins as well and then go michelins on the back next time they are due...the thing is the offside front tyre is fine for wear 6/7mm and I'm loathe to replace a tyre that doesnt need replacing (plus it is a bit beat up cosmetically so probably wont be very resellable) given they are not cheap...
the rears are the recommend 265/35
What would you do?
What would you do?
