Tyre sizes for 7x17 rim
233
233
21 Nov 2004
Wishaw
What would be the best size for a 7" wide rim
I'm thinking a 225/45/17 will be ok but would be interested to hear what you guys think
What width were the rims 7.5?
Ordered new wheels for the taxi but their only 7" width
Think that 225 might be a bit too wide for a 7" rim
stock size is 195/65/15 but its currently running an almost identical diameter 205/55/16
moving up to 17's 225/45 is the perfect size to keep rolling radius the same as stock size (the 205/55/16 is 0.3% different from standard so within tolerance, really wouldn't want to go anymore thatn 1.5-2% difference in RR which limits me to either 225 or 215 45 17s (the 215/45 is 1.26% out compared to stock.
my only worry is that a 225 is going to be too wide for a 7" rim and I would be better staying with the 215/45
225 is too wide for a 7" wheel. It's about as big as you would go on a 7.5" rim IMO. I run 225/45/16 on a 16x7.5. 215 max I'd say.
Found this table earlier as I was looking at something similar:
Rim width | Min | Ideal Tyre | Max
05.0 Inch | 155 | 165 or 175 | 185
05.5 Inch | 165 | 175 or 185 | 195
06.0 Inch | 175 | 185 or 195 | 205
06.5 Inch | 185 | 195 or 205 | 215
07.0 Inch | 195 | 205 or 215 | 225
07.5 Inch | 205 | 215 or 225 | 235
08.0 Inch | 215 | 225 or 235 | 245
08.5 Inch | 225 | 235 or 245 | 255
09.0 Inch | 235 | 245 or 255 | 265
09.5 Inch | 245 | 255 or 265 | 275
10.0 Inch | 255 | 265 or 275 | 285
10.5 Inch | 265 | 275 or 285 | 295
11.0 Inch | 275 | 285 or 295 | 305
11.5 Inch | 285 | 295 or 305 | 315
12.0 Inch | 295 | 305 or 315 | 325
12.5 Inch | 305 | 315 or 325 | 335
Going up to see my tyre fitter on Monday to trial fit a few sizes see how clearance is and how the tyre sits on the rim thinking about 215/45 stm
