tyre sizes for a 2002 focus
28 Jul 2003
South Wales
I'm confused about the tyre sizes.
Everywhere i look online suggests that the tyre size should be 195/55 R15 yet mine have 195/60 R15.
can anyone with a focus shed any light?
Your focus bought new or used? If it was a used car, the previous owners probably put 60 profile tyres on it because they were cheaper.
i need one tyre immediately cos it's flat, but the other 3 will need replacing in about 3-4000 tops.
my just change them all now.
are these any good?
TOYO PROXES T1-R 195/55 R15 85V Rim-protection £45.70 each then £10-£12 fitting.
On my 2002 focus the tyres are P6000 195/60/R15 88V, even in the manual is says this is what they are supposed to be.
Princey said:
They may of changed for the face lift though, 2001 onwards.
It did change, but I dont think they changed with the facelift though, because facelift wheels changed to 16" I think. Not totally sure, but there were two changes anyhow :D
found the 195/60 R15 proxes in a H rating for £40. Seing as my focus will only do 120 downhill and back wind am i right in thinking that the H rating (up to 130) will be ok over the V rating (up to 150) on the car at the moment?
are the CF-1 different to the TR-1?
H rating should be fine, its what I'm getting next anyway.
