Tyre spray marks help
18 Oct 2002
Derby
Does anyone know how to get tyre spray marks off a Tarmac drive? I've used some autoglym tyre spray & it's left 4 marks on the driveway (yes I know I've been a plank).
So does anyone have any tips other than don't do it again?
Alternatively for future, maybe spray it into an old aerosol can lid and brush it on... or sponge
Or if you really want to spray it from the bottle and can't avoid getting it on the ground, then roll the car back onto 4 little cardboard patches or something
Thanks for the tips, I'll give it a whirl later/tomorrow & be a bit more tactful with the spray next time!
