U Tubing?
22 Oct 2008
Lisburn
I've got a window punched out of my old 600t side panel and I wanted to put some U tubing round the cutting edge so I can fit some plexi against the hole to make a window. My theme is a black and red build. Would black U tubing be a better option or red?
Does OCUK sell the stuff? Witht he new site layout I can't find things easy any more :/
A little bit yes due to the cutting of the case side. It's more to cover any sharp edges and to have a decent seal when I push the plexi against it to make the window. I'm using the case for a new window as my full acrylic side will show the LEDs up wheras the new windowed side will have just the light showing and not the actual LED themselves.
If you Google C-Edge Moulding or Blow Hole Trim.
You'll find some :)
