Hi
Is it ok to connect a PC to the DVI port and another PC to the VGA port on these monitors? The initial setup manual says to use one or the other but I cant tell whether this is just for the initial setup or forever?
The monitor software allows you to switch between inputs; ideally I want my server connected to the VGA port and my main PC to the DVI port.
Any ideas?
Any ideas?
