Uber router build
20 Feb 2011
I was thinking about whacking together some old parts to make a multi network ported server doo dah to replace my wifi router. I'd likely run Windows on it just to get started. Would I be able to plug my BT fibre modem into this machine and feed all my network attached things via the multi network port cards? If so then gravy. The only thing that's bothering me is how to send a wifi signal out so my phone and tablet can connect to the net - can I just attach a wireless card and that'll be that?
Using Windows for this makes no sense at all.
If you're going to do it then choose one of the existing Linux/BSD distributions created for the task. pfSense is an obvious option, but there are plenty of alternatives.
Unless you have a specific reason for doing this you'd almost certainly be better off just getting a decent off the shelf router.
More NICs if you want multiple networks, else like rroff says.
I'd go pfsense, or OpenWRT x86 if you fancy a challenge. Personally, pF everytime.
I'd probably still use a managed switch with VLAN support unless it was something specific (they are so cheap its not really worth doing anything else these days).
Pfsense is exactly what I'm after. Thanks all for the suggestion. My current network is quite small at around five devices so I'm trying to avoid a switch just for neatness. For those wondering, I already have a decent router but, you know, it's no challenge! I'll likely try pfsense as an ESXi VM and see how I get on.
Pfsense is exactly what I'm after. ...
I'm using pfSense at the moment with a fanless Celeron mini-ITX box(I read a post somewhere that it can shift around 900 Mb/s from the WAN, but don't hold me to that). I think the next version of pfSense will have hardware accelerated encryption for CPUs that support it(not mine). I like it so far so will probably stick with it for a while.
EDIT:
Check out the pfSense forum or the sub-reddit.
