- 8 Aug 2003
Hi guys,
I'm about to drop a grand on the following kit, it's an upgrade from an aging p4 system, using it mainly for hi-end dtp and general multimedia and of course mabye a bit of crysis.
It's going to go in my existing case along with my hiper 580w psu, which should be enough according to a psu calc I did the other day.
Looking for advice, especially re: cpu cooler choice, i want it to physically fit to mobo!, and ensure that its as quiet as possible in the £50 price range...
Ram good choice? I want to go with 8gb, not sure on best ram to use though.
Also not sure on the overclocking side, would like to dable in that so advice on that would be ace!
thanks in advance, spec below:
Product Name Qty Price Line Total
Asus P5K3 Deluxe WiFi Intel P35 (Socket 775) PCI-Express DDR3 Motherboard £139.99
(£164.49) £139.99
(£164.49)
Microsoft Windows Vista Ultimate 64-Bit Edition DVD - OEM - 1Pk (66R-00838) £101.99
(£119.84) £101.99
(£119.84)
OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £151.99
(£178.59) £151.99
(£178.59)
OCZ 4GB (2 x 2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK) £139.99
(£164.49) £279.98
(£328.98)
Western Digital Caviar SE16 500GB SATA-II 16MB Cache - OEM (WD5000AAKS) £63.99
(£75.19) £127.98
(£150.38)
Intel Core 2 Quad Pro Q6600 "Energy Efficient 95W Edition" 2.40GHz (1066FSB) - Retail £159.99
(£187.99) £159.99
(£187.99)
Zalman CNPS9700-NT nVidia Tritium CPU Cooler (Socket 754/939/940/AM2/LGA775) £43.99
(£51.69) £43.99
(£51.69)
(£164.49) £139.99
(£164.49)
(£119.84) £101.99
(£119.84)
(£178.59) £151.99
(£178.59)
(£164.49) £279.98
(£328.98)
(£75.19) £127.98
(£150.38)
(£187.99) £159.99
(£187.99)
(£51.69) £43.99
(£51.69)
