Until today I’ve been running a successful wireless network comprising:
1 x 8Port POE switch 60W (5-8 are POE)
With the following connected via cat6 POE:
1 x Cloudkey
2 x APAC LR
Now, today, I ran a Cat6 run from the Switch in the loft, outside the house, over the Sky Dish cable directly behind the dish, into the lower room downstairs, approx 15m.
Cable tested (basic) all passed.
Attached new AP AC LR and it it going mental.
It alternates between...
Connected (wireless uplink)
to
Isolated
I’ve swapped the cables at the switch and the existing APs work fine on port 8.
I’ve recrimped with new RJ45 and the same problem exists.
Ive yet to swap the APs around to test the cables, but there is clearly a problem. The switch indicates POE is active but no data is transferring - it will only adopt and connect wirelessly to a weak signal from the closest other AP.
Any ideas what the problem may be here? I don’t think the Sky cable will cause interference as both the cat6 and the Sky Cable will be shielded. I’m wondering if the sky dish itself is causing interference?
Also considering that the AP may be faulty too.
1 x Cloudkey
2 x APAC LR
to
Isolated
