- 19 Mar 2009
- Leicester
Hi,
Sorry might be a bit of a long and detailed post but I am hoping for a big home network upgrade with Cat6a wiring for 10G connectivity and trying to plan out which way to go with my wiring options. Hoping this is going to be a long term upgrade and forget about it solution.
So a little background. Currently I have VM broadband 350Mbps, coming in the front right corner of house. Im using the HUB3 as a router and its connected to a 2 unit Orbi 852 Mesh system in AP mode which acts as a bridge. One AP is next to the router and the other is in our office which is on the first floor, front left of the house (this is where most of my hardware is currently).
This has been working well nice a stable, I am getting about 900mbps down the backhaul but there are a few niggles:
1) HUB3 is a rubbish router and it wont let me set up static IPs the way I would like
2) I have something of a wifi dead zone in the kitchen (back left ground floor) - which I think is a due to the office Orbi being above it.
My plans are to create a cupboard on the ground floor under the stairs with a rack and move my home server, main switch and general gubbins under the stairs and from there run Cat6a up through the walls (I have a new build so mainly hollow!) to the office and a couple of other choice points (the router, the lounge, the main bedroom etc).
So my question is this...
1) Should I stick with what I have and add in say an 8port 10G switch to the mix with the option down the line of upgrading the Orbi to 970's to improve wifi coverage (I think they have better 360 antennas so hopefully should hit the kitchen better).
The Cat6a will also mean I can start using the Orbi system in router mode and should get better control of IPs and I would have a wired backhaul.
2) Move over to a Ubiquiti system and take the opportunity while im running wires to place some in the ceilings/walls for POE access points. I have no experience with Ubiquiti hardware but looking at their website I was thinking I would need:
-Switch pro XG 10/24 POE
-2-3 AP U7 pro XGS as access points.
-would I need anything else?
Looking at the specs the switch will do DHCP so does that mean I can take the HUB3 into modem mode and the switch will act as a router?
My house is a 3 storey new build with a breeze block spine in the centre of the house where the stairs are and I am keen to get good high speed wifi coverage with aim of multigig internet in the future. Would I be better with a single ceiling mounted access point in the centre of house near the stairs on each floor (this would leave them all on one side of the breeze block spine and I worry wifi coverage would be weaker on the other side. Or wall mounting (vertically orientated) access points on the centre floor, basically back to back on either side of the breeze blocks to give me an access point on each side.
Sorry for all the questions. Keen to get the wiring situation right as I dont want to have to go back and damage walls all over again
Many thanks for everyone's thoughts in advance.
