Ubisoft: console makers are 'pressuring them' into 30FPS for PC
Status
Not open for further replies.
8 Aug 2010
Oxfordshire
Obviously this parity thing hasn't gone far enough yet. PC should be limited to 900p as well.. then we don't need GTX 980's. Let's all rejoice in visual parity and gameplay.
Link
Why are Ubisoft the only major developers moaning about this? Maybe if they didn't keep rushing rubbish out of the doors and concentrated on quality instead...
New consoles will bring PC advancements they said...
They will do, just ignore this sort of stuff from the likes of Ubisoft. They have a history of being easily "pressured" in to doing stuff if money is involved. Remember Assassin's Creed and the DX10.1 issue? nVidia had a hissy fit that the DX10.1 paths meant that AMD's cards were running faster than theirs, so it got removed with a pathetic "excuse" as to why.
This just makes the whole ps4/xbox 900p thing more fishy i bet the ps4 can run assassins creed at 1080p just fine. 900p isn't even a big deal to me but the idea that we have paid good money for a console that's having its resolution reduced for no good reason makes me loose respect for them.That said they 900p thing may be legit but reading more stuff like this makes me doubt it more.
I just won't buy anymore ubisoft games. Problem solved.
First they came for Square Enix, and I did not speak out—
Because I was not a fan of Tomb Raider.
Then they came for Ubisoft, and I did not speak out—
Because I was not a fan of Watchdogs.
Then they came for...
Nope, Ubisoft and the experts in this forum say it is just CPU limited..
Nothing to do with this whatsoever...
So you started the thread on the xbox bundle and there were no biters so you have had a rethink and ended up with the exact same thread that got closed.
10/10
Status
