- 12 Jan 2006
I Am at my wits end after struggling to get this working all week.
I basically want the ability to run perl scripts which use CGI.
I am a complete linux noob in terms of setting things up so bear with me.
The kernel is 2.6.15-51, and the version of Ubuntu is "Ubuntu-Server 6.06.2"
ok, so here is my script
using perl test.pl it works fine, the output is as expected.
The error log says:
Now this lead me to think it was the permissions, but both the file and the cgi-bin directory is set to chmod 755
I have xserver and webmin installed but couldnt work out how to configure cgi-bin so have just been doing it manually.
Here is my site file:
Now ultimately i want the scripts to run from /var/www/cgi-bin because thats where all my website files are (index.html works from the /var/www directory)
Any help would be MUCH appreciated
Code:
#!/usr/local/bin/perl
print "Content-type: text/html\n\n";
use CGI::Carp qw(fatalsToBrowser);
print "<HTML><HEAD><TITLE>Hello, world!</TITLE></HEAD>";
print "<BODY><H1>Hello, world!</H1></BODY></HTML>";
The error log says:
Code:
[Thu Apr 10 18:42:13 2008] [error] [client 192.168.1.2] (2)No such file or directory: exec of '/usr/lib/cgi-bin/test.pl' failed
[Thu Apr 10 18:42:13 2008] [error] [client 192.168.1.2] Premature end of script headers: test.pl
Code:
NameVirtualHost *
<VirtualHost *>
ServerAdmin webmaster@localhost
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
# Uncomment this directive is you want to see apache2's
# default start page (in /apache2-default) when you go to /
#RedirectMatch ^/$ /apache2-default/
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ScriptAlias /cgi/bin /var/www/cgi-bin/
<Directory /var/www/cgi-bin>
Options ExecCGI
AddHandler cgi-script cgi pl
</Directory>
ErrorLog /var/log/apache2/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog /var/log/apache2/access.log combined
ServerSignature On
Alias /doc/ "/usr/share/doc/"
<Directory "/usr/share/doc/">
Options Indexes MultiViews FollowSymLinks
AllowOverride None
Order deny,allow
Deny from all
Allow from 127.0.0.0/255.0.0.0 ::1/128
</Directory>
</VirtualHost>
