Hey all, just done a fresh install of Win 7 on my old laptop (Dell Inspiron 630M) after getting it back off the wife!. Decided to dual boot with Ubuntu to try it, and also hopefully interest our youngest son (turning into a bit of a geek!
) in something other than Windows.
Anyway, installed fine, everything seems to work fine, i stick all the info in for my ethernet or wifi connection and it accepts everything but keeps reverting the gateway IP to 0.0.0.0 after i click apply, everything else stays as it should?.
My WiFi card (Intel 2200) is supported as standard, so can anyone help?.
) in something other than Windows.Anyway, installed fine, everything seems to work fine, i stick all the info in for my ethernet or wifi connection and it accepts everything but keeps reverting the gateway IP to 0.0.0.0 after i click apply, everything else stays as it should?.
