- 25 Jun 2005
Hi all,
I was trying out some DVD ripping programs yesterday, put the PC into standby now this morning it won't load.
It starts by showing the boot menu to choose what to load, select the normal install and it goes to the purple screen with ubuntu written on it.
From here it goes to a blank screen where the CPU revs up to max and then down. It does this until I power off.
Any ideas how I fix my install? I don't want to format/reinstall cos there are some pics i've not put on the 1TB drive yet. I also don't want to reinstall as that seems a damn inelegant solution without any skill or learning.
I can take a vid if it helps of what it does.
