Ubuntu 9.10 Grub issue
8 Nov 2003
UK
Hi,
More of an annoyance than an issue...
For some reason when I start up the computer I have to press enter in Grub to get Ubuntu started.
I don't dual boot or anything and haven't adjusted any grub settings to my knowledge.
How do I get it to automatically select as it used to?
Thanks
Check /boot/grub/menu.lst for an entry that starts with "default". also check for an item that starts with "timeout". Fairly self explanatory options, to choose a default kernel to boot, the list starts at 0, not 1.
EDIT: erm... grub 2, I know nothing about... the above is only grub 1 (probably)
Probably not all relevant but tried the 9.04->9.10 upgrade earlier and it borked by setup. Not even going to THINK about upgrading to 9.10.
Strange I've upgraded my laptop to 9.10 without issue I also upgraded the other halfs laptop from 8.04->8.10->9.04->9.10 in one afternoon. I've hear people say they have had issues with upgrading but it's something I've never had a problem with.
Well I think you might be one of the fortunate ones, even most of the Ubuntu crowd seem to strongly suggest avoiding the upgrade function, and just doing a fresh reinstall with a 9.10 DVD. Wish I known about all the problems before I bothered:p
Here is my grub.conf:
Code:
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT="2"
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="ipv6.disable=1 quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entrys
#GRUB_DISABLE_LINUX_RECOVERY="true"
Edit: Fixed.
I altered GRUB_DEFAULT=0 to GRUB_DEFAULT=saved then ran sudo update-grub :)
