Man of Honour
- 18 Oct 2002
I've started my vmware distro install-fest for the reason a) I can get a first hand view on poplular distro's on offer b) It'll be easier for me to help forum members with their distro if I had the same distro they're using - and perhaps explain a distro specific GUI method of doing something rather than the usual CLI method I explain (plain because thats the only thing thats common thoughout all distros).
Well after Robmiller mentioned Ubuntu as a up and coming distro gaining good replutation I took al ook at their website. Based upon Debian I figured that it must be at least half decent so I've decided this will be the first distro of many to be vmwared.
Installing-wise couldn't be easier, it doens't use a graphical interface ala Fedora, Mandrake or SuSE but uses a text based menu system like on slackware and freebsd. Nevertheless the install procedure is as easy as they come, very straight forward, I didn't at any point need to go back and redo anything (I should have took some screenshots, I did think about but then didn't). Typically a beginner would just choose the automatic install procedue like I did rather than the manual method of choosing packages, and automatic really is automatic, there was hadly anything to type in, eveything was auto detected and installed - it even detected that I was using vmware and used vmware drivers for XFree.
Upon installing everything Ubuntu ask wether it has a direct connection to the net. If you choose "yes" (which is recommended) it automatically syncs with it's ubuntu servers and uses apt-get to update the entire system. After about 10mins you're presented with the funky looking ubuntu login screen.
Honestly I'm impressed, it looks nice (plenty of eye candy) but at the same time the GUI doens't feel too bloated (and we are talking about gnome here) theres no clutter of menu and icons that all do the same thing, it's just feel simple and nice. I'm yet to work out how to use apt-get but really I think this is the distro that I'm going to be recommending to beginners from now on
Here is a good starter guide for Ubuntu
I did only play with it for 5-10 mins after installing though (maybe I should have used it longer before posting my comments eh). Yes it seems as easy to use as Suse's Yast does
