ubuntu flashing error after installation
11 Oct 2008
hey guys, i have installed ubunto on my pc from both a cd and usb stick, all works fine the first time it loads after install, but any time after that i get a flashing error just after all the bios messages.
the flashing message says:
ussplash: setting mode 1152x864 failed
ussplash using mode 1024x768
ubuntu 9.10 james-desktop tty1
james-desktop login:
im using the latest 32 bit version from the offical website
this is my first time using linux, does anyone have any ideas on how i can fix this? thanks for any help
okay type in your password and username
then try this command
sudo start x
that should start up the GUI
tell us what happens
look like the graphics card drivers are failing and u will have to install drivers.
Looks like usplash is trying to load a resolution that won't work, then defaulting to one that might. Usplash - by definition - doesn't use the graphic card driver, but it does use parameters which the renoundly un-reliable ubuntu monitor detection thing may have set, settings which also might be preventing X from starting.
Do you see a white pulsing ubuntu logo at any point?
What is the native resolution of your monitor.
Can you log in with your name and password, then issue this command:
Code:
more /etc/X11/xorg.conf
Show us what it says back (space to move to the next page).
