Ubuntu help required...
Caporegime
26 Dec 2003
Hi,
I just installed Ubuntu 7.10 x86 on my laptop, during installed it gave some error due to not being connected to the internet at all and was unable to fetch some files(?).
Now, it's running and wireless is set up perfectly but update manager is not showing any updates when I do a check.
Any idea how to fix this so I can update?
it just says 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
when i run update manager it tells me i'm all up-to-date, but the cd image was from october so doubtful?
I'm going to try installing it again with network cable plugged in this time.
It's funny, every time I try Linux some annoying bug/issue takes the shine off another wise good desktop OS. :(
Sorry I didn't come in on this sooner, if you do not have an internet conection when you install. Then at least sometimes, the repos are not on by defaut, all you have to do is go into software sources or the repositorys in Synaptic or add/remove, then check them to active.
