Ubuntu/kubuntu resources
25 Oct 2002
Can anyone please recommend some sites/guides to get started with ubuntu or kubuntu as i want to have a dabble?
You don't really need a guide... if you want to dabble then run it as a live session, that way you don't have to install anything.
So, just download the ISO, burn it, boot from the CD and it will run as a live session with an install option on the desktop.
Thanks.
I'm downloading 6.10 and 7.04. Is it better to try 6.10 as i have heard there is more support available than with the newer version?
7.04 should have a lot more fixes / improved hardware support over 6.10.
For support: http://ubuntuforums.org/
As 6.10 has been out longer (October 2006) there will naturally be more support available, however some of the issues you may have with with 6.10 would most likely have been fixed with 7.04 (April 2007).
