Ubuntu + Lilo help
Zom
Zom
18 Oct 2002
I couldn't install grub during installation and so I installed lilo. However, I can't boot windows, I know the partition is still there but I just can't boot into it. Can anybody help? Let me know what config files I need to post and I will do so.
Thanks in advance
you need to post it's configuration, but i don't know exactly where it is. it should be in /boot/lilo/ and look for a file like menu, config, something like that. in GRUB it's menu.lst should really learn how LILO works someday...
You need to post /etc/lilo.conf
I dont use lilo often but if you post that I'm sure one of the guys that do can point you in the right direction :)
I'm afraid I bottled and just did a re-install of ubuntu. Thankfully this time grub would install and so I can now dual boot. :)
Thanks anyway guys.
