Ubuntu Live USB question
1 Jul 2007
Various
I'm planning on installing Eee Ubuntu 8.04 to a USB stick to use, oddly enough, on my Eee PC. I just have a couple of questions. I only have one USB stick. If I put the ISO onto it using unetbootin, and let it load up in the same way that a live CD would, can I then install the OS back to that same USB stick? I assume that I can, as it will have loaded the Live OS to the RAM...am I right?
I think that unless you had it writing to a separate partition it would fail to work properly. If you want to try you'll need to be sure to tell it to load completely into memory at boot. By default it does not.
