Ubuntu problem
16 Oct 2007
UK
dear all,
im having a problem with ubuntu..
i dont think i've changed or done anything, but whenever i try to use the package manager, it says
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/dpkg/status
E: The package lists or status file could not be parsed or opened.
E: _cache->open() failed, please report.
W: Encountered status field in a non-version description
any ideas?
thank you!
edit: scrub that... not really a good idea.
Here's a better suggestion...
copy /var/lib/dpkg/status somewhere else temporarily....
sudo mv /var/lib/dpkg/status /var/lib/dpkg/status-borked
replace status with a version Ubuntu backed up automagically called status-old...
sudo cp /var/lib/dpkg/status-old /var/lib/dpkg/status
run an apt-get update command to see if it worked...
sudo apt-get update
