UBUNTU:resolution problem!
8 Jan 2004
CORNWALL
trying to boot my ubuntu on 800x600, but cant do it.
at the minute its on 640x480, here is my xorg file
Code:
Section "Screen"
        Identifier      "Default Screen"
        Device          "VMWare Inc [VMWare SVGA II] PCI Display Adapter"
        Monitor         "Generic Monitor"
        DefaultDepth    16
        SubSection "Display"
                Depth           1
                Modes           "640x480"
        EndSubSection
                Depth           4
                Modes           "640x480"
        EndSubSection
                Depth           8
                Modes           "1024x768" "800x600" "640x480"
        EndSubSection
                Depth           15
                Modes           "640x480"
        EndSubSection
                Depth           16
                Modes           "640x480"
        EndSubSection
                Depth           24
                Modes           "800x600"
        EndSubSection
EndSection
any ideas? what do i need to change-thanks
Default depth is set to 16 so it's probably using 640x480 in the Display SubSection with Depth set to 16. Try either:
Code:
                Depth           16
                Modes           [b]"800x600"[/b] "640x480"
EndSubSection
or set DefaultDepth to 24 (higher colour depth than 16).
tried
Code:
                Depth           16
                Modes           "800x600" "640x480"
EndSubSection
login screen comes up in 800x600, after logining screen goes back to 640x480.
The reason that once you log on the resolution changes is gnome thinks you want to use 640*480.
Change this in the screen resolution dialog in the settings menu.
