Ubuntu : Sound not working
3 Sep 2008
I recently bought myself a new HTPC, built it and installed ubuntu.
Everything is working perfectly, apart from I cannot get it to play any sound.
Motherboard is MSI FM2-A75IA-E53 - Using onboard sound
How do I reinstall sound drivers on ubuntu?
Spoogle,
On Linux drivers are usually built into the operating system, therefore re-installing drivers is a bit of a duff concept in Linux.
The best thing to do is open a terminal, and run the following command:
lspci
This will list all the devices connect on the PCI bus, one of which should be your sound card, and hopefully we can then do a bit of googling to find if it is supported under Linux.
What outputs are you trying to use on your sound card, coax, 3.5 jack, hdmi?
If you open a terminal and type:
alsamixer
What do you get, an error message, some equalizer bars? If you get equalizer bars are any of them muted (show MM at the bottom of the bar).
A long shot might be to try what is documented here:
http://www.webupd8.org/2010/11/fix-hda-intel-realtek-alc887-no-sound.html
I know some of the ALC cards are sometimes wrongly detected, so setting it to generic might get you something at least.
