Hi guys,
I'm having a very strange problem and I wondered if anyone could help shed some light on it.
I'm running Ubuntu Linux (7.10-64) in a virtual machine on top of Windows Vista. The free version of VMServer I'm using only lets you allocate two "processors" to each VM, which is fine since I'm running a Q6600. Now, as far as Ubuntu is concerned, it is running on a 2-core processor with 512mb RAM and 3GB hard disk space. I'm using the computer to run folding@home so I downloaded the SMP client (which utilizes more than one cpu/core) and set that to work in Ubuntu.
Back in windows, I open up the task manager and notice the Virtual Machine process is only using 25% of the CPU i.e. one core. So, I switched to the virtual machine and ran Ubuntu's System Monitor which shows (correctly) cpu0 and cpu1. However, only "100%" of the system resources are being used. I'll explain it as I understand it:
1 core = 100%
2 cores = 200%
When SMP client is running the following is true:
core0 = 0% core1 = 100%
Now, if I open an application such as firefox and keep an eye on the system monitor the readout is:
core0 = 30% core1 = 70%
The operating system seems to only be using a 100% split over both cores.
Truth be told, I don't know if this is an Ubuntu issue, a VMWare issue or even a folding@home issue. I just wondered if anyone had any ideas before I delete the machine and reinstall it.
I'm a bit of a Linux newb so please don't assume I've tried things that might seem obvious to yourselves.
Thanks for your time.
1 core = 100%
2 cores = 200%
