UE-V and/or UPD
30 Sep 2005
HI all,
Just wondering if anyone has any experience on a large scale environment with either UE-V and/or UPD.
I'm looking for a seamless user experience across both traditional windows desktops and RDS, but with fast logon times.
UPD would be perfect apart from the fact it only works on RDS. Can you have a mix between UE-V and UPD :confused:
Thanks :D
Just a heads up for anyone looking to roll UE-V out
What Microsoft doesn't tell you, is that the data gets saved in a hidden folder!! I spent three hours troubleshooting this, until I switched on "view hidden files/folders" lol
We use UEV for about a dozen apps, its worked fine and replaced roaming profiles. The UEV folders are stored on member server and it has grown pretty large since it was implemented a couple of year ago. Microsoft say it's only a few KB for each template, but things like Firefox can grow pretty big for each user if they install plugins and do some customisation. Yes, hidden folders need to be purged as part of any user deletion process.
