- 22 Aug 2014
- Nottingham
Hi all. I hope someone can help me out with this one. It's been doing my head in and I've been at it for nearly 2 weeks, it seems no matter what I do I can not get the ultra fast boot to work. Always tells me your graphics cad does not support UEFI GOP and csm disable.
Mobo
Asrock 970 extreme3 r2.0
Bios p1.60 (latest)
GFX
powercolor R9 270 scs3 2gb ddr5 silent fanless
RAM
8gb ram. 2x4gb dual channel. 1866 ddr3
CPU
AMD FX8320. Running stock with a corsair h55 liquid cooler.
HDD
Muskin 120gb (100% health with ssd life)
320gb Sata2 hdd. Be changing this to a 1tb WD next week
I have windows 8.1 pro 64bit installed in UEFI mode. SSD definitely set to that GPT partition thingy.
Boot order
Windows boot manager (SSD)
Rest is disabled.
It works no problem with fast boot. Which has CSM Disabled. So I know the card works with that disabled.
My motherboard does not have on board graphics so can't even test that way.
I have contacted asrock. They been trying to help but nothing makes a difference.
I have contacted powercolor. Send some details they wanted but I know I won't hear anything till Monday about that.
It does say on the box UEFI READY. and on powercolor website.
My vbios is 015.041.000.000.000000 (113-C6300100-x27)
Has anyone else had a problem getting this working. Or any tips on what else I could try. I really would like to use ultra fast boot. My computer boots in 25 seconds anyway but if it can go faster then I want it to.
Thanks guys.
Mobo
Bios p1.60 (latest)
GFX
RAM
CPU
HDD
Boot order
Rest is disabled.
Thanks guys.
