Hey guys, Recently got my new computer, and it is amazing! Only problem is that 2 or 3 times a day i get a BSOD...
I checked the Minidump files and it's saying something about VISTA_DRIVER_FAULT and ntoskrnl.exe driver fault.
This is what the Dump File reads:
Thanks for any help you can give
<3
Code:
Loading Dump File [C:\Users\Nico\Desktop\100210-21122-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7600.16617.amd64fre.win7_gdr.100618-1621
Machine Name:
Kernel base = 0xfffff800`02a1e000 PsLoadedModuleList = 0xfffff800`02c5be50
Debug session time: Sat Oct 2 15:59:55.289 2010 (UTC + 1:00)
System Uptime: 0 days 4:09:36.710
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {2b, 2, 0, fffff80002a6ddaa}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Your debugger is not using the correct symbols ***
*** In order for this command to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** work. ***
Probably caused by : ntoskrnl.exe ( nt+4fdaa )
Followup: MachineOwner
3: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 000000000000002b, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80002a6ddaa, address which referenced memory
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
Use '!findthebuild' command to search for the target build information.
If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff80002a1e000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4c1c44a9
READ_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPoolCodeStart
unable to get nt!MmPoolCodeEnd
000000000000002b
CURRENT_IRQL: 0
FAULTING_IP:
nt+4fdaa
fffff800`02a6ddaa 0fb6472b movzx eax,byte ptr [rdi+2Bh]
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0xA
LAST_CONTROL_TRANSFER: from fffff80002a8dca9 to fffff80002a8e740
STACK_TEXT:
fffff880`0aae5838 fffff800`02a8dca9 : 00000000`0000000a 00000000`0000002b 00000000`00000002 00000000`00000000 : nt+0x70740
fffff880`0aae5840 00000000`0000000a : 00000000`0000002b 00000000`00000002 00000000`00000000 fffff800`02a6ddaa : nt+0x6fca9
fffff880`0aae5848 00000000`0000002b : 00000000`00000002 00000000`00000000 fffff800`02a6ddaa 00000000`00000000 : 0xa
fffff880`0aae5850 00000000`00000002 : 00000000`00000000 fffff800`02a6ddaa 00000000`00000000 66264438`33343836 : 0x2b
fffff880`0aae5858 00000000`00000000 : fffff800`02a6ddaa 00000000`00000000 66264438`33343836 2e313d72`6f746361 : 0x2
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
nt+4fdaa
SYMBOL_NAME: nt+4fdaa
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntoskrnl.exe
BUCKET_ID: WRONG_SYMBOLS
<3
