** UK FIRST - AFFORDABLE GAMING MICE FROM CORSAIR **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Corsair have stormed the market with their vengeance gaming peripheral range recently.
The new Raptor series gaming mice are designed to offer the benefits of the higher end gaming mice in a more affordable package.
Don't be fooled, the Raptor series are still full fat gaming mice but the pricing is a lot more aggressive on these brand new models.
Stock is on order and due to be with us any day now.
Corsair RAPTOR M30 Gaming Mouse (CH-9000042-EU) @ £34.99 inc VAT
The Corsair Raptor M30 gaming mouse is designed to provide great performance. The high performance 4000 DPI optical sensor is tuned for accurate linear tracking, with no acceleration or predication, so every movement translates directly into the game. On-the-fly DPI adjustments, six mouse buttons and extra large PTFE glide pads improve your response time for faster shots and quicker escapes. Plus the contoured right-handed design features a comfortable rubber thumb grip and soft-touch finish so you can log the game hours you need to play your best.
• Game tuned 4000 DPI optical sensor ¡V Highly linear tracking for accurate mouse control in games
• Six button design ¡V Set frequently used in game actions to mouse buttons for faster access
• On-the-fly DPI adjustment ¡V Switch dpi with a single click for tight shots and fast getaways
• Soft-touch surfaces and rubber grip - Outstanding comfort and control during extended gaming sessions
• 1000Hz response rate - Faster polling rate for smoother response to your actual movements
• Extra large PTFE glide pads - Low-friction glide pads ensure smooth and precise movements
• High Performance ADNS-3090 Optical Mouse Sensor
• Up to 60 inches per second and 20g motion detection
• Up to 4000 DPI with 800/1600/3200/4000 steps
• 1000hz response rate
• Six button design (including mouse wheel and dpi switch)
• Low-friction braided cable (1.8m)
• Dimensions: 130 x 70 x 45mm
• Approximate Total Weight: 148g (w/cable)
Only £34.99 inc VAT.
ORDER NOW
Corsair RAPTOR M40 Gaming Mouse (CH-9000041-EU) @ £44.99 inc VAT
The Corsair Raptor M40 combines performance gaming features with the comfortable responsiveness of an optical mouse. The game tuned 4000 DPI optical sensor delivers accurate linear tracking—with no acceleration or predication—so every movement translates directly into game play. The adjustable weight system lets you fine tune both weight and balance to your playing style. On-the-fly DPI adjustments and seven fully programmable mouse buttons improve response time for faster shots and quicker escapes. Plus the right handed design includes key comfort features such as soft touch finishes, a low-friction braided cable and extended PTFE mouse feet to maximize your gaming experience.
• Advanced weight system ¡V Customize both mouse weight and balance for your style of play
• Seven programmable buttons ¡V Set frequently used actions, macros or keystrokes to dedicated mouse buttons for faster access
• Selectable USB response time ¡V Choose between 1000, 500, 250 and 125Hz
• Adjustable lift height ¡V Five selectable lift height levels
• Soft-touch surfaces ¡V Outstanding comfort during multi-hour play sessions
• Onboard memory ¡V Save mouse settings for use on other PCs
• Corsair Mouse Software ¡V Setup macros, create keystrokes, adjust dpi and save settings directly to your mouse
• Selectable USB Response Rates (1000/500/250/125Hz)
• Weight system: 3x 1.5g screws, 3x 4g weights, 16.5g total adjustability
• Dimensions: 118 x 72 x 39mm
• Approximate Total Weight: 150g (w/ cable and weights)
• Omron switches
• Extra Large PTFE mouse feet
Only £44.99 inc VAT.
ORDER NOW
Order Date: 2 Sep, 10, 2:21 pm
Logitech MX518 Gaming-Grade Optical Mouse (910-000616) £19.57 1 £19.57
That is affordable.
Still using it today.
The markup on 'gaming' mice must be insane.
Really like the M30. Though it looks like a polished version of the RAPTOR-GAMING M3 DKT - mouse released last year by Raptor gaming. Perhaps they are a sub brand of Corsair?
Edit - just seen the news article that Corsair aquired Raptor gaming. Looks very nice I may have to change.
Is the palm bit of it longer than a G500 as I find my palm drags on the matt a lot?
That is affordable.
I agree here, the markup on gaming mice is through the roof and a huge con at that. A lot of pros are still using Intellimouse 3.0 / WMO mice and own everyone. The only reason you see pro players using such gaming mice, is because they're told to do so by their sponsor(s) (as it's in their contract to use the sponsor's equipment).
I have a G500 and hated it. The swappable scroll wheel was awful as it made it feel sub par in both usage situations. The sensor housing kept coming loose and wobbling during tracking at low DPI settings and the braiding on the cable was useless as it snagged itself once and then was permanently bent/knotted.
That said the M40 is barely any cheaper than the M65 which is a damn fine mouse and I'd say definitely worth the little extra outlay, unless you absolutely have to have an optical sensor.
That is affordable.
Still running my old 518 :cool:
Think the M30 looks good but the M40 looks pap. Can't see me replacing my 518 though until I have to.
Not sure on the pricing for the M40 when you can pick up a M90 for £44.99 and a M60 for £50. Maybe I'm missing something here?
That M30 looks awful in my opinion...
Surely Corsair could have done better than that? :p
The M40 looks the business though. :cool:
