ULTIMA PAINKILLER MAX PAYNE 3 SYSTEM
11 Dec 2005
Cheshire
"Ultima Painkiller" Intel Core i7 3770K 3.40GHz @ 4.80GHz DDR3 Max Payne 3 Limited Edition Quad Core System @ £1,999.98 inc VAT
Introducing the "Ultima Painkiller", the new ultra high end gaming system from Overclockers UK. Designed and engineered specifically for the launch of Rockstar's brand new game; Max Payne 3.
Continuing the saga of the infamous Max Payne, the setting has now changed to the exotic streets of São Paulo, Brazil where the city is displayed in full DX11 glory, courtesy of the Euphoria dynamic animation engine. With new features to the game series such as cinematic action movements, interactive cut scene and absolutely zero loading screens during gameplay combining with next gen DX11 graphics, you will need a powerhouse of a system to play the game maxed out! This is where out "Ultima Painkiller" steps in.
Based on the brand new Intel Z77 platform the "Ultima Painkiller" has all the latest next generation features necessary for future proof computing such as USB 3.0, SATA 6GB/s, Intel Ethernet and SSD caching.
Re-defining speed with the Intel core i7 3770K CPU overclocked to a mighty 4.80GHz, featuring true quad core performance with hyper threading to bring the count to a total of 8 threads. However speed equals heat, luckily for us our professional in house technicians have constructed an totally custom water loop, to keep the CPU running at ultra cool temps. With ultra yellow watercooling fluid, the "Ultima Painkiller" does look truly striking.
A titanic 16GB of Corsair Vengeance running at 1600MHz provides ample memory for even the most demanding of programs, including Max Payne 3 where it keeps the game running silky smooth. That is some serious power but what use is power if there is nothing to take advantage of it? Well this is where it gets interesting.
Equipped with the storming new Nvidia GeForce GTX 670 2048MB GDDR5 graphics card providing sublime DX11 cinematic graphics delivering a breath taking visual experience. For the ultra hard core gamers where enough is just not simply enough, we offer the option to dual wield and SLI two of these awesome graphics together for game destroying performance. Scaling perfectly in SLI, with unlimited bandwidth, courtesy of the overclocked Intel Core i7 3770K.
Storage is key and the "Ultima Painkiller" is no different, packing a grand total of two SSD's and one mechanical HDD. Both Intel Series 330 SSDs, the first larger drive has a 120GB storage capacity and is the primary boot drive; the second SSD has a 60GB storage capacity which is reserved especially just for the Max Payne 3 install. The Max Payne 3 install is over 35GB in size so having a separate SSD to keep clutter free sweetens the deal even more. Finally a 1TB Hitachi HDD serves as a storage/media drive, useful for storing all of your media and game backups etc.
** FREE COPY OF MAX PAYNE 3 ** - If ordered before 1st of June, game will be sent to you upon day of release (1st June)
Why You Should Buy This System
- A guaranteed 4.60GHz+ performance for the price of 3.40GHz
- Nvidia GeForce GTX 670 with powerful DX11 graphics
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- Creative Sound Blaster Recon3D sound card provides superb surround sound
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- All systems with an operating system selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012
System Specification
- Case: NZXT 810 Switch Big Tower Case - Black
- Power Supply: OCZ ZX 850w PSU
- CPU: Intel Core i7 3770K 3.50GHz @ 4.80GHz Ivybridge CPU
- Motherboard: Asus P8Z77-V DELUXE Intel Z77 (Socket 1155) DDR3 Motherboard
- RAM: Corsair Vengeance 16GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: 60GB SSD, 120GB SSD & 1TB HDD
- Graphics Card: Nvidia GeForce GTX 670 2048MB GDDR5 w/ SLI Option available
- Sound: Creative Sound Blaster Recon3D Sound Card
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter - Black
Watercooling Specification
- Radiator: XSPC EX360 Radiator
- Pump/reservoir: XSPC X2O 750 Dual Bay Resevoir/Pump Combo
- CPU Block: EK Supreme HF - Nickel Plexi
- Fittings: x6 OcUK Fatboy 7/16" Barbs - Nickel
- Tubing: x2 XSPC Tubing - 1m (Total 3 metres)
- Fans: x3 Bitfenix Spectre White LED 120mm Fan
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
With an ultra high overclock and the ever powerful Nvidia GeForce GTX 670, you can game like never before.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods. S
Only £1,999.98 inc VAT.
ORDER NOW
