**ULTIMA QUASAR ULTIMATE GAMING PC!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Check out this new bad boy, with the very best hardware and NZXT's latest chassis, cooler and PSU:-
"Ultima Quasar" Intel Core i7 3770k 3.50GHz @ 4.60GHz 16GB DDR3 Mpowered Ultimate Gaming PC @ £1,575.96 inc VAT
The "Ultima Quasar" features an Intel Core i7 3770k overclocked and guaranteed to a stable 4.60GHz. With four processing cores with hyperthreading and dual channel DDR3 memory the "Ultima Quasar" powers through applications and games with equal ease. A titanic 16GB of DDR3 RAM is featured, overclocked to 1866MHz, you have never seen speeds like these before! Primary storage and secondary storage we leave for you to select, though we recommend a Samsung or Intel SSD for the boot drive and 2-3TB for the storage drive. Last but not least is the brutal MSI HD 7970 Lightning Boost Edition graphics card, a true fire breathing beast with 3GB of VRAM and a GPU core speed of 1150MHz! Hammering out fantastic DX11 graphics with ease. If one is just simply not enough, you can double up and go Crossfire and really have a weapon on your hands.
A system of this specification can easily handle the latest games such as Farcry3 and Skyrim at maximum detail settings even at resolutions upto 2560x1600. If your serious about gaming or just want a truly powerful PC then the Ultima Quasar is for you.
Why Should You Buy This System?
- A guaranteed 4.60GHz performance for the price of 3.50GHz
- Quad Core processing with hyperthreading and DX11 performance.
- Dual Channel DDR3 overclocked to 1866MHz
- USB 3.0 compatible system
- 8 Hours stressed tested and quality controlled
- Precision built and cabled by Overclockers UK expert technicians
- All systems with an Windows 7 selected ship out with a pre-installed 180 day trial of Panda Antivirus 2012. Not compatible with Windows 8.
System Specification
- Case: NZXT Phantom 820 Enthusiast Full Tower Case - Gunmetal Grey with LED strip programmable to any colour (default choice, options available)
- Power Supply: NZXT Hale 1000w Gold Rated PSU
- CPU: Intel Core i7 3770k 3.50GHz @ 4.60GHz CPU
- Motherboard: MSI Z77 Mpower Intel Z77 (Socket 1155) DDR3 Motherboard
- Cooler: NZXT Kraken X60 CPU Hybrid Water-Cooler w/ x2 NZXT Fans
- RAM: Avexir Mpower 16GB (2x8GB) 1600MHz C10 Dual Channel with Blue LED strobe lights
- Hard Drive: Select from drop down options
- Graphics Card: MSI HD 7970 Lightning Boost Edition 3072MB (Crossfire option available)
- Sound: Onboard 7.1 Channel Sound Card
- Optical Drive: Select from options
- All Orders placed on the 22nd October 2012 and after shall recieve FREE copies of FARCRY3, Hitman Absolution, Sleeping Dogs PC Games along with 20% off the latest Medal of Honor WarFighter. This bundle is worth in the region of £100 and is completely FREE (Subject to availability) - You will recieve your gamecode from 2nd November onwards in the email address you provided when placing your order!
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Go beserk, with the "Ultima Quasar" and decimate the opposition with the brute power within!
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
*Fast track service subject to current stock levels during busier periods.
*Buy any system from Overclockers UK with Windows 7 between now and January 31st 2013 and once launched, you can upgrade to Windows 8 for just £14.99! See full details here:http://www.overclockers.co.uk/LP/windows8_upgrade.php
Was [£1,675.96] Inc. VAT
Only £1,575.96 inc VAT.
ORDER NOW
As soon as we sell one of these bad boys we shall do a full build log and post plenty of images as the new NZXT 820 case is absolutely stunning and the programmable LED's really set this case off. :)
i was about to buy one but then i saw the case is a tad too tall to fit in my desk, i only have room for about 22 inch of height and this is over that :mad:
it was quite an expensive desk and im really fond of it, here you will see why i am very limited to something no taller than 22 inches or so due to restriction of the desk, my old antec 900 is showing its age
