- 11 Dec 2005
- Cheshire
Fantastic savings to be made on our "Ultima" system range! Either Intel or AMD, make your choice.
"Ultima Raptor" AMD Phenom II X6 Six Core 1090T Black Edition 3.20GHz @ 4.00GHz DDR3 System @ £949.99 inc VAT
The "Ultima Raptor" features an AMD Phenom II X6 Six Core 1090T Black Edition overclocked and guaranteed to a stable 4.00GHz. With six processing cores and dual channel DDR3 memory the "Ultima Raptor" powers through applications and games with equal ease.
Why Should You Buy This System?
- A guaranteed 4.00GHz performance for the price of 3.20GHz
- Six Core processing and DX11 performance.
- USB 3.0 and SATA-III compatible system
- Precision built and cabled by Overclockers UK expert technicians
System Specification
- Case: Antec 902 Ultimate Gaming Case - Black
- Power Supply: OCZ StealthXStream II 600w
- CPU: AMD Phenom II X6 Six Core 1090T Black Edition 3.20Ghz overclocked to 4.00Ghz
- Motherboard: Asus Crosshair IV Formula 890FX
- Cooler: Akasa Venom CPU Cooler
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz
- Hard Drive: Seagate Barracuda 500GB 16MB Cache
- Graphics Card: Choice of the latest DX11 graphics cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Want to be the first to harness the power of AMD Six Core? If you enjoy smooth framerates and rapid loading times at an excellent price point, this system is for you.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
The lead time on all pre-built systems is between 24-48 hours.
Was £1229.99 Inc. VAT
Only £949.99 inc VAT.
ORDER NOW
"Ultima Hydrophobia" Intel Core i7 920 D0 2.66GHz @ 4.00GHz DDR3 H2O System @ £1,099.98 inc VAT
The "Ultima Hydrophobia" features a Intel i7 920 D0 2.66GHz processor overclocked and guaranteed to a stable 4.00GHz. With a full custom watercooling loop pre-installed the "Ultima Hydrophobia" features silent operation with ultra low temperatures allowing the processer to be overclocked to the highest standard. With a ATI Radeon 5770 providing the latest DX11 graphics you can select Cross fire option to double your firepower.
- The 4.00GHz overclock ensures lightning fast processing speeds
- Massive 1TB hard drive that delivers rapid load times
- Custom Watercooling for ultimate performance and silence
- Featuring DX11 cinematic graphics
- Case: Coolermaster CM 690 Dominator II
- Power Supply: OCZ StealthXStream II 700W
- CPU: Intel Core i7 920 D0 2.66GHz Overclocked to 4.00GHz
- Motherboard: Asus P6T Deluxe OC Palm Edition (Socket 1366) PCI-Express DDR3 Motherboard
- RAM: Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
- Hard Drive: Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache
- Graphics Card: Asus ATI Radeon HD 5770 CuCore 1024MB GDDR5 with Crossfire Option available
Watercooling Specification
- Radiator: Black Ice Stealth GT 240mm Radiator
- Pump/Reservoir: XSPC Dual Bay Reservoir/pump (750lph)
- CPU Block: EK Supreme HF Nickel Universal CPU block
- Fittings: x6 Bitspower 1/2" Stubby Barbs Black Sparkle
- Tubing: x2 Masterkleer 7/16" Tubing - 1m (Total 2 metres)
- Fans: x2 Akasa Blue LED 120mm Fan (38.4CFM, 17.5dB)
Service Package
The "Ultima Hydrophobia" provides ultimate performance, cooling and stylish looks in one awesome package. If you like to game with more power, the "Ultima Hydrophobia" is for you.
Was £1199.99 Inc. VAT
Only £1,099.98 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
