Ultima Vanquish
31 Aug 2010
Hi, first off I want to apologize if i come off as extremely newbie or retarded as I have no idea with computers but what I know is that my computer is dying and it can barely run half life 1.
I am planning to upgrade my old computer to a an ultima vanquish but I am not sure if the system itself is just a bundle of hardwares and you wuold have to assemble or it's totally built up and ready to go? I am really confused with this as I have no experience in building computers. Would I be able to just install the OS from the get go ( I have a windows 7 x64 cd ) and free to play?
Thanks!
Hi and welcome, no if you buy one of the systems its already pre-assembled for you, if you want to have a go at building it yourself you can just select the components you want and theyll ship them to you so you can build, this is normally a bit cheaper, depends how comfortable you are
All our system range are pre-built machines so you will recieve the comkputer fully built up and ready to plug in and go.
If you select an OS from us we will also install it for you with all the drivers present so you literally have to power on the machine.
If it is just HL1 you want to play the Vanquish may be a little overkill for you.
Our most popular gaming system is the Titan Xenomorph which features the GTX 460 which is an excellent graphics card and the i3 530 CPU overclocked to 4.2GHz which is a ridiculously quick speed!
Well I'm planning to start playing the new games I've been buying but failed to run on my old computer. Hopefully it should last me till diablo 3 comes out.
Also, last question since i already have an OS with me, could I just install that and download the drivers for the hardware and I should be ready to go, amirite?
Thanks for the helpful reply!!!
Yeah you can order without OS so you can install it yourself.
All depends what your budget is to be honest, if you want something alittle more powerful we have an i5 system Titan Exodus and AMD Quad core system Titan Cyborg. Both are quad core so they have a lot more oomph.
Thanks for the suggestions! I'm planning to pick the vanquish which should last me for quite a while hopefully. Also, it seems futureproof enough that it wouldn't need much upgrading in the future unless I'm really keen on maxing games in the future. With the tolerance I had with my old PC playing starcraft 2 on low settings and lowest resolution possible, I shall be solved with this. Thanks for the reply and service.
