An opulent, mysterious, and perilous fortress is the setting as Bruce Lee seeks to claim infinite wealth and the secret of immortality from the wizard who dwells within.
You begin your search for the wizard at the entrance to his fortress. This chamber, and each chamber here, is sealed off from the other rooms. The only way to get from one room to the adjoining room is to jump up and take the lanterns which hang from the ceiling. When you get all the lanterns (or at least certain lanterns) for that room, the door opens. (Watch the edges of your screen so that you’ll see when your exit is possible.) Hint: You must get all of the lanterns in the first three rooms in order to proceed. Then go to the middle room and look for the opening through which you can exit.
Throughout your search for the wizard, you are attacked by the ninja brandishing their BOKKEN sticks. Even more dangerous is the Yamo, who runs after you and delivers crushing kicks. Duck and run away to foil their attempts to harm you, then come back kicking and chopping. Take as many lanterns and cover as much ground as you can before these foes reappear.
To get around each room, you can climb vines (up, down, or sideways), ride on waves of particles which change direction at random, leap from ledge to ledge, and jump down from a ledge without injury.
Hazards and traps await you in rooms close to the wizard’s chamber. You must avoid electrical charges passing through gaps between ledges, PAN lights streaming across the floor, and exploding T’SUNG-LIN (bushes) appearing from nowhere.
When you finally reach the wizard, keep away from the fire balls streaming from his head.
Unlock and complete every game mode to become the Ultimate bruce lee. Some modes are unlocked by completing others modes, some by killing a certain amount of bad guys and others by collecting the golden bruce lee statues.
http://www.ovine.net/392/ultimate-bruce-lee/
( not the same as the normal bruce lee remake posted in the database )
