Ultimate Skulltrail gtx
I wouldnt bother, they are overkill and price performance isnt as good as other offerings from overclockers, you can have a faster performing pc for under £2000
Then buy a 30" with the change
thats what id do. an amzing pc for £2000 then add a 30" dell for perfection
hardware looses money to fast to spend that much on it
id get that if u want the ultimate gaming machine event hat is overkill tbh
i agree, thats what you should get, although id get rid of 2 WD's and go for 1 samsung F1, or 2?.. much cheaper and very very little difference
and prob get 4870X2 or 2X4870 (on diff mobo obviously)
why does everyone say this, theres loads of difference look at the response time not just the mb/s for once please !!!
You'll find that most people here will be looking at response times rather than transfer rates.
I think, more to the point, the VelociRaptor drives are a bad buy, they are just so damn expensive, and not a massive amount faster than a more common 7200RPM drive.
Skulltrail is generally a bad buy as well, mainly because of the ludicrous price, and that you will barely use four cores, let alone eight.
What size display are you going to playing on?
Thanks for all the info.
Talked to overclockers uk and hav ordered a new system from them them.
I belive this system is a new variant as it is not yet on ther system.
I belive they will name the system (Bluebird) app £2500 + vat???
Thanks again.
