- 16 Aug 2007
I'm completely dissatsifed with the current upgrade path to vista and the general windows path of adding flashy3D nonsense and bloated code that eats away at progress in PC performance. I've been experimenting with Win XP, Win 2k, Win Vista, Ubuntu Linux, Fedora Linux, Suse Linux and Mandriva linux and I've decided to standardise my PCs at home on Windows 2000 Professional because it seems to be the best current balance for performance computing - licences can be bought very cheaply indeed, it has almost all the features of WinXP (certainly all I need) and seems to run several times faster on equivalent hardware.
I've already got win2k running on my fileserver at home, have just formatted my work laptop with a win2k build and installed win2k on my home workstation (main PC used). The workstation I use at home is an old Compaq W6000 with twin Xeon 2.0ghz and 2gb of funny old RDRAM.
Given the workstation is due for replacement, what is the best PC to replace it with to give maximum performance but without features/cores etc that will simply lie unused on win2k??? AFAIK, win2k pro "sort of" supports hyperthreading and can only use a max of two processors (physical or logical I'm not sure). Is this correct?
Given the limitations of win 2k pro (esp regards today's multi-core processors), what am I best going for in a new workstation??? Twin single-core chips at the highest clock speed available? A single dual-core chip at the highest clock speed available? Given the option of perhaps switching to a windows 2000 server OS install rather than win2k pro, what are the specs machine to look for then? Really can't seem to find a clear answer as to whether a top-spec quad-core desktop/workstation of the moment would be utilised by win 2k pro or win 2k server...
Anyone help me out here?
Cheers
Dan
Cheers
Dan
