Well I read somewhere the other day that placing a 2p under the X bracket would help even out core temps...
System Spec: Q6600 - Lapped, Ultra 120 Extreme - Lapped
Prior to doing this @ 3.825 Ghz on my Q6600 my load temps were 68/68/62/62, the hotter two cores being the ones at the top of the CPU i.e. where the weight of the heatsink pulls the base most away from the CPU..
So after a couple of cuts (damm those fins are sharp) and a few swear words later had removed the heatsink and taken out the screw on the X bracket so that the bracket would lay flat on the 2p....
Then reassembled the heatsink with 2p (and much swearing!!) and rebuilt my rig...
after 30 mins Prime95 temps were as follows: 63/63/60/60
5c drop on the top 2 cores and a couple of c on bottom 2 can't be bad!!!
Have to say am pleased with the results still recon there is a little room for improvement... by pressing down on the heatsink can drop the temps to 60/60/59/59 so plan on trying it with two 2p's stuck together tomorrow evening... will report back then..
