Ultra High Speed HDMI Cable 2.1
Yup - basically HDMI is a standard that defines what the cable should be to be able to transmit HDMI signal without it failing. It's digital - it will either work or not.
Use the truehq ones myself and no issues, although any cable will do. Unless running over 10m then go for a fiber optic one.
I like the slim ones, certified and far more flexible.
Deal: Ultra Thin HDMI 2.1 Cable 8K 1.5M, Stouchi Hyper Slim HDMI 2.1 Cable, Extremely Flexible 8K HDMI Cable, Supports 10K 8K120 4K120 144 Hz, eARC HDR10 4:4:4 HDCP 2.2&2.3 Dolby Compatible with PS5/Xbox/LG https://amzn.eu/d/43S1uSe
oooo you get pretty wooden blocks
A bargain at £5000 for 3m.
Make sure you get a good quality power cable to go with it.
If anything - don’t try to sell the standards and signalling technology of HDMI as something special only your cable has..
Differential signalling it’s part of the HDMI standard lol and your £2.99 cable will provide the same level of performance over 3 meters if it’s certified HDMI.
I got a Club3D (I think) 5m cable and it's been fairly reliable, it's quite sketchy territory when you get to 5M and beyond and a lot of cables seem "fake"
I was told by cable salesman these Nordost HDMI cables have superior like analogue like vinyl sound quality, so I said "PLEASE TAKE ALL MY MONIES" and he did.
