Ultra m.2 pci e 3.0 x4
Status
Not open for further replies.
22 Feb 2015
My motherboard has this feature http://www.asrock.com/news/index.asp?id=2121
I was going to sell my 240gb sandisk extreme pro and buy a Samsung sm951 m.2 ssd. This would give me speeds up to 1700+ on the write and 1500+ on the read as opposed to my current 500+.
My question is, will this steal pci e 3.0 lanes / bandwidth from my gpu?
If so, will it limit gpu performance?
Can this be used as a boot drive? (as i want to remove all my drive cages and other ssds). The big one is 512gb which is enough for me.
I have i7 4790k
Thanks for the help guys!
found my answer, kind of disappointing:
"But there is a problem. On the Intel Z97 platform PCI Express 3.0 is only supported by the microprocessor itself. The CPU has 16 PCI Express 3.0 lanes that can be used to connect a graphics card in PCIe 3.0 x16 mode or reconfigured as 8+8 lanes (to support a dual-GPU configuration) or 8+4+4 lanes (to support a multi-GPU or multi-PCIe devices configuration). As a result, once an SSD in plugged into the Ultra M.2 slot, the bandwidth between central processing unit and graphics processing unit is cut-down by half. Therefore, while the end-user gets additional SSD performance, he/she may lose some GPU performance because of insufficient bandwidth between it and the CPU."
as of:
http://www.kitguru.net/components/m...m-2-ssds-with-ultra-m-2-but-there-is-a-catch/
Status
