Ultrabook under £500
7 Mar 2011
UK
Can anyone recommend an Ultrabook (or slim/light laptop) for sub £500 which meets the following spec:
15" screen +
Scrabble tile keyboard
W7 or W8
SSD not HDD
Under 1.5kgs
Preferably a:
Lenovo
Acer
Asus
Any ideas?
To throw my two cents in here,
being sick of 1366x768 being acceptable in 2012 I've got my eye on
http://www.gigabyte.com/products/product-page.aspx?pid=4210#sp
It'll set you back a grand though. But probably worth it to avoid such a low res panel and gain some nvidia graphics in an ultrabook chassis. Though it's 14" not 15" and it's 1.6kg but I have my eye on it since it has upgradable RAM and mSATA and SATA drives. None of that soldered rubbish, don't wanna be on 4gb of RAM in 3 years time with a 128GB SSD.
That's a gorgeous spec machine, the finish is so so. I didn't even know Giga makes hardware other than boards.
Are there any reviews?
Nice. Quite buncy though, considering a Macbook Pro isn't far off the same cash. To spend £1k+ on any type of laptop these days, really has to be seriously justified I think.
Does anyone know much about the AMD CPU or battery capacity in the Lenovo S206? It seems very cheap, but those two specs look concerning.
