I have an Acer 38" ultrawide monitor mounted on an Ergotron Dual LX. It works fine, but the monitor sits a bit low for ergonomics. I have tried adjusting, but with the weight of the monitor (7.81kg), it will only adjust so high.
Can you recommend a quality ultrawide compatible monitor stand?
